lawrosa wrote:
I dont see the rougue but they do have onethats $225 bucks I think..
Where you don't see it, on Ebay? :) Yes, $225:
MPPT 2024.
Manual.lawrosa wrote:
Just the wire from the solar will be the issue...
Drill hole in roof??? Uggg.
You already have several big and small holes in the roof. No need to reinvent the wheel. Check the list of completed solar projects somewhere here on the forum. Some people drilled hole in the roof, though majority used the fridge vent and routed it inside the cabinets and then to the storage. Or mounted controller inside the rig, close to batteries. Mine is in bedroom, batteries are in storage under the bedroom 3ft away, cable goes to battery through 3/4" interior wall.
