Well here is a quick pic of what I got..
Its a pretty good unit IMO for $110 bucks.. It does what it says..
Enter system voltage...
I got 16.11 amps fron an 37 volt 8.7 amp panel.. Not bad.. I had evetything running I could in the camper...
Stove fan, vent fan, every light( All LED), a 100 watt box fan, and the heater fan.. It was hard to kill the batterys.. Battery voltage was showing 12.1 volts with everything running...
Standing in front of panel amps way down...
I set the bulk charge at 14.8volts on this controller.. After it went out of bulk and into float @ 13.6 volts it showed about 3 amps...
So I increased the float to 14.5 volts for float and the amps increased to about 10 amps. I left it there until the amps went down to 3 amps again then change the float back to 13.6.. The unit then went into sleep mode..
I am going to use this as a portable.. I have about 50 ft of 8 gauge and will add a 8 gauge trolling motor plug from the MPPT and mount to front of camper.. I ordered both ends. This will let me plug in the panel and put the panel in the sun..
Trolling motor plugI also ordered this leg kit.. Its worth it as my machinist buddy said he cant make it cheaper..
Solar tilt kit..So Free panel
Free 8 gauge wire
$110 MPPT
$50 Tilt kit.
$30 8 gauge connector trolling motor
$10 8 gauge pin connectors..
Im into this for about $200 bucks...
Is it worth it? IDK.. I was happy with my truck alternator charging my batts for the weekend..
Here is my alt charging mod.. I thought I had a post on here about it.. I am a super mod in the DIY sites..
Seems mods here may be deleting my posts.. I dont know..
Charging rv batts from tow vehicle alternator...
