pianotuna's avatar
pianotuna
Nomad III
Aug 26, 2018
solar in the rain.
Hi,
Finally a day that is smoky and rainy. Output to the (hungry) battery bank is 3.3 amps at 1:00 p.m. local time on August 26, 2018.
Panels are from 2005 (Unisolar) and are connected in series parallel with an input voltage of 33 to a Blue Sky 3024 di MPPT controller. This is a flat fixed installation of 256 watts. The wire from the panels to a combiner box is 4 #12 (dual wires to each panel). From the combiner box to the controller is #10 (prewire from factory). From the controller to the dual battery bank is #8 with a 25 amp fuse. There is a catastrophic failure fuse at the positive post on each of the dual banks. The batteries are 4 used telecom jars, wired in a balanced manner, with an OEM capacity of 556 amp-hours @ as volts.
  • Almot's avatar
    Almot
    Explorer III
    Don is pretty far North, I think 50-something.
  • I do not thnk PTs Unisolars are amorphorus.
    I've seen various outputs from 0 to 3 amps during rain events around noon here at 32' N, from 198 total watts. 130 watts of a poly framed Kyocera and 68 watts of Amorphorus pvl-68.
    Lots of variables as to what one could/should expect with cloudcover and or rain.
  • Almot's avatar
    Almot
    Explorer III
    3A from 256W in rain is impressive, amorphous Unisolar must have some sweet spot for this kind of conditions. Well, it's still summer, a lot of sun behind those clouds.
  • Twelve, ten and eight gauge might be a slight bit small depending on the distances but during rainy and smokey conditions, that’s not bad at all. Are you in bulk, absorption or float stage?
