gocamping14's avatar
gocamping14
Solar Kit Companies
Plan to purchase a solar portable kit, will fit our needs the best. Looking at kits from 100-200 watts in size. Many companies and options. Seeking pros and cons about the different companies and products. Thanks in advance...........SS
Looked at > gpelectric renogy wholesale solar go power
windy nation samplex solar harbor freight
  • I have found the Renogy products to be first rate. I have 1.3kw of their panels and associated items
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    smkettner wrote:
    SolarBLVD.com kits to compare
    Unless the kit is exactly what you want I would tend to build my own from components I choose. Panels are generic commodity. Wire is rarely the correct length. Kits often have the lowest cost controller.
    Some kits have the controller mounted on the panel. I think this is a bad idea unless the panels are very close to the RV batteries. If you want to run the portables 30+ feet out to catch the sun while you sit in the shade your charging voltage will suffer. Far better to have the controller near the batteries.
    x2 on locating/relocating the controller at the battery. I have run up to 150ft (#10 wire) to my panels to get them into the sun.
    solar blvd kits IMHO are reasonably priced.
  • SolarBLVD.com kits to compare
  • Anonymous's avatar
    Anonymous
    I bought a 120-watt folding kit from Solar Blvd. in CA last year for about $200 and I'm very pleased with the system.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
