Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
Sence your controller is rated at 30 amps, I would suggest wiring to efficiently be able to add panels if 200 watts isn't enough for your needs. My system is similar in size but the wiring is sized to handle 30 amps at less then 1% line loss. In my set up I believe I will need 300 watts but I am going to try 200 first. good luck with it!!
