64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
smkettner wrote:64thunderbolt wrote:No fuses between panels and controller. All connections to the battery should be fused to protect the wire. #10 need a 30 or 40 amp fuse.
Another question is should I install any fuses between the panels & controller or between the controller & batt or both???
BTW, 14.4 volts is fine. Plenty of people brag on long battery life with a PD converter that never goes above 14.4 volts.
