Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
Can the suitcase panel's 15awg cable bypass the existing controller and be attached to the added panel. From the added panel run 10awg to a new Solar30 controller at the MH Then 2feet of 10awg fused at 10amps to the batteries? I would add Anderson SB50 connectors for ease in setup and takedown. I believe this should cut the voltage drop, right?
