64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
DAS26miles wrote:
Can the suitcase panel's 15awg cable bypass the existing controller and be attached to the added panel. From the added panel run 10awg to a new Solar30 controller at the MH Then 2feet of 10awg fused at 10amps to the batteries? I would add Anderson SB50 connectors for ease in setup and takedown. I believe this should cut the voltage drop, right?
