64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
64thunderbolt wrote:
The kit came with #10 wire 20' with all the connectors which should be ample. My biggest concern is where to mount the controller. Someone said NOT to mount in the batt area due to degassing. WHY? I guess I could put it in the basement compartment and wire through the wall to the batt.
smkettner wrote:
Nice kit, looks plug and play. But how long is the included MC4 cable to reach the controller?
Wire them in parallel.
Is your PWM charger adjustable for voltage during bulk charge mode? If so, set it for 14.8V in bulk mode.
Mount the Charge controller as close to the batteries as possible, in the closest compartment that won't allow the controller to be exposed of off gassing while charging. 3 to 5 feet of 10 gauge wire from controller to batteries should minimize any voltage loss to 1% or less.
12 ga wire from panels to charge controller should be good for up to 20 amps of solar panel, you are currently at about 11 amps, max.
Perhaps a link to the kit that you bought, so we can see which model charge controller you got? If it's similar to the Amazon version kit, you'll want to scrap that charge controller asap and get something that is voltage adjustable in bulk charge mode to 14.8 to 15.0V for when you want to top charge, which should be daily, especially if you are dry camping for periods over 7 to 10 days in a row.
