64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
red31 wrote:NinerBikes wrote:red31 wrote:64thunderbolt wrote:
The controller only does 14.4
Measure it on a warm day, my $8 version claimed 14.6 but does 14.8 unless it's cold and maxes out at 15.0.
Show us a picture of your charge controller model, and a measure of voltage at the battery terminals some time. Those are good numbers.
The sun finaly came out! Info from someones weather station locally.
Charging vehicle battery w/60 watt panel, 50F
Move probe from controller Vout to batt
pianotuna wrote:
Hi 64thunderbolt,
6 to 8 feet is a bit long unless the controller has battery voltage sense wires. You can get away with it with big enough wire.
The boxers in the ring are the solar purists (me), the generator only folks, and the solar plus generator.
If you recharge using a genny it is important to force as many amps as possible into the battery bank in the shortest possible time. After all "time is money" when running a genny.
I hate to admit that when I went full time I had to get a genny. In hind site I wish I had beefed up the solar until I could run my roof air from that energy source, but I did not have the ready cash to do so.
When I was part time, my solar provided all the power I wanted for seven days at a time.
It is a friendly match btw. Quite Balanced LOL.64thunderbolt wrote:
WOW, didn't mean to start a fire. Just want to cut back on gen run time while dry camping & keep the batt up while stored in the back yard between trips. Like I said I have dry camped for over 16 yrs with no solar and have had good life with my batt. I had no idea there was so much science in this simple addition to my gen. I had 2 grp 27 marine/deepcycle's last 6 yrs. How long should they last?
BTW would 6/8' be too far between controller & batt?
markchengr wrote:
Some solar controllers, like mine, can be damaged by disconnecting the batteries without first removing the power from the PV panels because it gets its control power from the batteries. I installed a marine battery switch in the positive from the panels to the controller because of this. My controller is a SunCharger-30 PWM. There is a stern warning about this in the manual. YMMV. -Mark.
NinerBikes wrote:We are just talking about reducing generator time for the OP.smkettner wrote:On a pedestal in a campground with full hookups, perhaps, dry camping, not so much. You don't need solar if you're hooked up to a pedestal 24/7, then it's a non issue.
BTW, 14.4 volts is fine. Plenty of people brag on long battery life with a PD converter that never goes above 14.4 volts.
