64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
DAS26miles wrote:
This is addicting! Can I add another panel to the 2 already in the kit? The controller is 10amp and each of the 2 50watt panels I in my 100watt suitcase kit put out 2.7amps each or 5.5 for the 2 I have. Here is the panel- Renogy 50 watt panel
smaller wattage panels cost more per watt than bigger wattage panels. If you are going to expand, then don't nibble at it. Go way bigger and get it over with.
You can also run two solar sets each with its own controller on one battery bank. So you could keep the one you have as is, not wasting the controller for it, and get a totally different bigger set, and use that at the same time. Lots of ways to do it.
