64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
waynefi wrote:jrnymn7 wrote:
wayne said,
"I'm seeing about a 0.6 volt difference between the battery and the controller with 3.5 amps flowing. That is a bit more than I expected."
That is excessive voltage drop for only 3.5a. For example, I see .09v (point zero nine) drop at 45a. It may be simply a disagreement in meter readings, between the controller's display and whatever you used to read voltage at the batteries? Confirm all readings with a single handheld meter, to be sure.
About 0.1v seems to be a mismatch between the meters. This seems to be about 16 gauge wire, which would be .004 ohms/foot. 3 amps over 30 feet at .004 ohms/foot should be 0.36 volts
jrnymn7 wrote:
wayne said,
DAS26miles wrote:
What ever happened to the OP 64Thunderbolt. Sorry I ran off with his topic.
DAS26miles wrote:
SkiSmuggs, what do you think about it not topping off and leaving 5 amps? Do you have the ViewStar 1024n controller? If so, can you adjust the charging limits?
BFL13 wrote:
Seems like there is nothing wrong with the solar equipment. Just not enough time in daylight at this time of year. Add to that the long time it takes to recharge a battery from 90% to Full anyway.
DAS26miles wrote:
Forgot to mention the panels were up 6 hours and I moved them for maximum affect.
Another question: The controller has a readout that gives temperature and SOC. Where is the state of charge from, panels, contoller or batteries?
