64thunderbolt
Jan 31, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
SkiSmuggs wrote:
For those following and not happy with the Renogy controller not being programmable, Renogy sells a programmable model as well, originally StarView if memory serves, but now Solar30. My original suitcase system from them came with a 10 amp StarView which I programmed per the Trojan specs. It is always a good idea to check the settings as mine came set for AGM default.
DAS26miles wrote:
Thanks, you guys are correct about voltage. I went to Norcold site and checked manual on my N611.
"DC Voltage Requirements and Polarity
Operating controls require 10.5 to 15.4 Vdc to operate."
So 15.5V is the max.
DAS26miles wrote:
Ninerbikes-thanks for the info, at Quartzsite I used the generator with the Intelli power charge wizard and the Xantrex battery charger and when the volts got up to 14.4 on my battery monitor, I pulled both fuses for the fridge and furnace.
If I get a solar kit, I won't have to worry will I?
