PerryB67
Nov 14, 2021Explorer
StirCrazy wrote:
where does that come from. I did three weeks in the 5th wheel this sumer, and every night before I went to bed the four 6V batteries were 100% charged. then I did two weeks in the truck camper in september in alberta so using the furnace every night. I was back to 100% around noon every day and stayed there untill it started getting dark. definatly not just for "streatching" the period between recharging with a genny. if done properly it is a totaly replacment for a generator.
I had no problem understanding what BFL13 wrote. It depends on how long you want to be out before your batteries need charging.
StirCrazy wrote:The sub-forum Vehicle Mounted Systems in the DIY Solar Power Forum blows away any information I've been able to find anywhere else. And when you add in the other sub-forums there is no comparison. DYI has sub-forums that will never be here because of this forums dated software.
as to the OP's original question there are not any good forums or such when it comes to 12V rv related solar. there are some very good sites that deal with off grid and on grid high voltage static setups. its all relitive and you can take bits and pieces from there and apply it to here.
Enjoy,
Perry
