LittleBill
Mar 08, 2022Explorer
2oldman wrote:LittleBill wrote:There seems to be this misconception they do not, but they do.
lithium battery's drop voltage. not sure who told you they don't...
Actually I'm not sure if it's the BMS or the controller that's more in 'charge' of the charging. I set my Outback controller to the voltages specified, set Absorb to as near zero as possible, and it works fine.
The voltage will vary quite a bit when charging.. at least mine do.
the bms is safety system. its not suppose to engage unless there is an issue. that being overvoltage, undervoltage, temperature, cell voltage deviation and amperage.
the charger does all the charging. period.
