BFL13
Jan 16, 2019Explorer II
Solar on Roof -- How You Park-Series vs Parallel ? UPDATE
Update 8 March
Got my second 255w on the roof and went camping where I could check it all out. Solar here in January with such low sun angle is not worth much, but I was able to get some (IMO) interesting measurements.
I have a 255w at the back sloped down a bit and another up front flat. Between I have the three 100s flat. (see photo in profile--wood shows where three 100s are in the middle. New 255 in front of that, old 255 in back by cargo rails driver's side)
The back 255 is on an Eco-Worthy MPPT 20 amper and the front 255 is on a Tracer MPPT 20 amper where the controllers are in parallel on the battery bank. The middle array of three 100s in parallel, is on a PWM Solar30 amper also in parallel on the bank. ( I will add a photo of the roof if that works out)
No solar in the woods at the campground, but went to the library in town. I was parked nose down a bit on the street. Sun was toward the back, favouring the back 255.
I got, back to front:
3.43a, 3.8a, 2.9a. ( total = 10.13) Trimetric said batteries were getting 8.4 amps so load was 10.13-8.4 = 1.19a
I wanted to see what happened if parked more level, so I moved the C to where it might be better. Sun a bit more to the side too. (Also note it was closer to high noon by then, so amps better) This time I got, back to front:
3.86, 4.4a, 5.2a (total = 13.46)
So now the front 255 was doing better. Hmmm, what would all this be like if I had the panels in series all on one giant controller, so amps would depend on the lowest amps panel? Oops?
If I understand it, in the second example, if I only had the two 255s, I would get two 3.86 = 7.72a instead of 3.86 + 5.2= 9.06a as I got with them in parallel.
I then went to a place where it turned out one of the 255s was shaded and I got nothing from it, but got 4.56 and 4.4 from the other two arrays. If they were the usual set-up all in series, and that end of the roof were shaded, what would I have got?
So all in all, I know about the wiring to be saved and don't park in the shade in the first place, but still---I think I am better off as is.
These low amps don't mean much for differences between them, but in summer at full amps that could mean significant amps.
I think maybe there is more to the story about series vs parallel. A typical RV roof is not flat, but part of it slopes down at the back, so it can depend on how you are parked wrt to the sun, which is the "weakest" panel that will set the pace if they are in series.
Never mind the ugly mess, I don't care about it. It works!
BTW a previous owner tossed the air conditioner and put in a fantastic fan, so that is what you see. I don't have rain cover for it, but could if wanted( not needed) Panels cover two skylights (don't care) and part of the fridge vent cover, no problem. Roof is a mess of Eternabond bandages I did, plus Dicor goops as required. :) It is how it is!
