chloe_s_ranch's avatar
chloe_s_ranch
Explorer II
Jan 31, 2014
solar options
Last summer I had a 240 watt kit(from Solar Blvd.) Installed on our MH. It has two 120 watt panels feeding a 20 amp charge controller. I recently had the two stock 12 volt marine house batteries replaced with four Trojan T-105s since we almost always dry camp or boondock and wanted more amp hours to get us through the shoulder season when we run the heater more(and there is less sunlight.) We also hate running the generator because of the noise. I know a rough rule of thumb is about 1 watt of solar for each amp hour of battery capacity and I now have a 450 amp hour battery bank. So if I have more solar installed here are some options: A--Have another kit from Solar Blvd.installed with its own wiring and another 20 amp charge controller so both kits would work in parallel charging the batteries. They have a 300 watt kit for $500. Or B--get their 120 watt kit and have them swap out the 20 amp charge controller for a Blue Sky sb3000i 30 amp mppt charge controller for about $500 also. I know option B would require heavier gage wiring since all three panels would be wired together feeding a single controller. Or option C--get the 300 watt kit and pay a little more to swap out the 20 amp pwm charge controller for a 40 amp pwm charge controller and wire all four panels into it. Again needing heavier gauge wiring. It seems to me that option A(having two separate kits feeding two separate 20 amp pwm charge controllers) offers the most bang for the buck. What are your thoughts?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
