robatthelake
Oct 11, 2013Explorer
Forget the 20 Watt Panels, they are next to useless! Just arrange the highest Wattage Panels that You can afford on the Flat surface of Your Roof for Maximum Charging capabilities!
To answer the question about using several panels ,there really is no limit to the number that You use other than having a suitable charge controller!
That little device is limited by the amperage it is designed to handle.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
