JiminDenver
Aug 10, 2015Explorer II
So what I see is that the solar isn't keeping up with usage. The LED lights for the battery and tanks are not acceptable for showing battery charge, useless is more like it.
If you did discharge your battery a single flat mounted 100w panel isn't going to be enough to recharge it especially if you are still using power. The next time turn the truck around and use the jumper cables to do some bulk charging for a hour or so and give the solar a chance to finish it up. Many do it with a generator in the morning when the sun is low and little comes in from the solar.
It would be a hassle but you could pull the panel down and track the sun with it. This would pretty much double your harvest in a day.
More info is needed like type of batteries and more info on the solar and loads.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
