Colo_Native
Mar 08, 2016Explorer
JiminDenver wrote:
In the compartment you run the risk of the acid fumes damaging the controller. It may be okay if the compartment is vented well enough or with AGM. What's the distance outside of the compartment?
I believe they are sealed Group27 batteries, The other place is in the storage compartment on the other side of the 3/4' wall the compartment which would interfere with storage. I really want to use the front compartment on under the over hang and it is vented because the propane are on both sides divided by a small wall that is open on top plus the batteries are covered
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
