Muddydogs's avatar
Muddydogs
Solar panel disconnect switch.
What do you guy’s recommend for a Solar panel disconnect switch?
I'm thinking that I don't want my battery’s always connected to the solar panel while the trailer is in storage. I pull the main battery disconnect switch so the trailer isn’t drawing power while setting. Also it would be nice to turn off the solar juice in the winter when I pull the battery’s and take them home for storage.
  • I was worried that 4 100 watt panels might cook the batteries during the summer months in the blazing Utah sun. Actually I was kind of thinking about hooking 3 panels together for the run to the controller with an off switch then running wire for 1 panel separate to the controller and leaving it charging all the time for a maintainer? Yes, no, I'm way over thinking this?
  • Hi Muddy,
    You may as well use a breaker.
    Before I full timed I left my batteries in the storage area with the solar active. That worked for me for 13 years.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
