CT_WANDERER
Jan 04, 2015Explorer
jrnymn7 wrote:
It has been recommended to allow at least 20% of head room. Don't forget, current creates a lot of heat, so you need to oversize your controller considerably. I went with a 30 amper for my pair of 140w/8.15a Isc panels. I wouldn't go with anything less than a 50a controller with your panels, especially being in a cooler climate such as yours.
And make sure you wire accordingly, to avoid excessive volt drop.
I always do my own work and go with heavy wire than needed. So wiring voltage drop should not be a problem.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
