CT_WANDERERExplorerJan 04, 2015Solar Panel Disconnected from SUNI am planning installing 4X140W panels(parallel)flat mounted going to 15A breakers(so they can be switched off if needed) to the charge. The panel have ISC of 7.50 each times 4 equal 30. The controlle...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentSolar panelSolar panelSolar panel disconnect switch.Fuse panel locatecheap solar panels
