CA_Traveler
Apr 15, 2023Explorer III
Series panels is likely a non starter (for RVs) for half cell panels because all series panels need to have the same amps to maximize power. All series strings in a series/parallel setup strings need to have the same voltage to maximize power. Of course there is a shadow pattern where this will happen but is this effective? Full cell parallel panel strings also have to have the same voltage on each series string to maximize power.
ie For series panels identical amps is a primary consideration and for parallel panels identical voltage is a primary consideration.
Updated
Updated
