CA_Traveler
Sep 28, 2023Explorer III
Those panels are very efficient with low light. 92% @ 100 Wm2. Combined wiith the very efficient Victron MPPT contorller the output would be the same as a similar panel with full cut cells.
Half cut panels are designed to work to improve performance with a unique shadow pattern of larger grid arrays and a contoller that operates with both power points. But if starting over I'd look hard at the same panels and the Victron controllerl
