mena661 wrote:
smkettner wrote:
I would buy 1.5" angle aluminum at Home Depot and cut/drill my own.
You may want to locate your own hole position or have two holes into the roof. Or maybe you want 2" wide or 3" wide.
$15 for 36" piece of aluminum. Cut as you like. Drill to match the shape & slope of the roof.
Or maybe 2" angle is better.
Thanks smk. I don't have anything to cut aluminum with but I'll keep in mind anyways.
hmknightnc wrote:
Might be timely for Mena, since I'll be testing it with 265watts solar and will definitely try to max it out
Looking forward to the testing!
Buy a hack saw, or find a local buddy in construction trades with a sawzall and a new 36 tooth/inch blade, and you can cut aluminum angle extrusions. File the burrs off after you cut to clean things up and to prevent from getting cut by sharp edges doing the install.
Edit: SMkettner already posted, I'm late to the party, sorry.
