Hi mena,
I was speaking of power dissipation at the controller.
There would be better heat tolerance on the roof if the panels have room for air to flow under them.
Here is an english video of the solar 30
solar 30 EnglishThe solar 30 does do temperature compensation--but at the controller--not at the actual battery. Since the controller should not be in the battery bay--it may not be too successful at temperature compensation. There needs to be a probe that fastens to either a battery post--or sticks on the side of the battery. I'd prefer the battery post method as it has a better chance of knowing the internal temperature of the battery bank.
mena661 wrote:
pianotuna wrote:
Hi mena,
Power dissipation is not going to be a problem with 300 watts of panels.
Would I not see a difference if I put raised them up an inch or two? New info to me so any explanation helps. If it's not important then I won't worry about it.
