mena661 wrote:
Saw THESE on ebay. I'm going to get two 150W panels from Solarblvd. Should I wait till I get the panels or will these do? Thanks.
Panel
http://www.solarblvd.com/Solar-Panels-&-Systems-12-Volt-Solar-Panels/c1_269/p2868/Solar-Cynergy-150-Watt-12-Volt-Solar-Panel-PV-SC150J12/product_info.html
Since you've decided to go with PWM, the 140 watt panels, in addition to being less expensive, have a better amp rating than the 150 watt models.
8.00 Amps, look at the specs. The 17.0V is not critical, it gets bumped down to 14.4v by your charge controller anyways, so less voltage losses.
Solar Blvd 140 watt panel specs.IMHO, I'd buy the 140's. If they fit, size wise, on your roof.
