BFL13
Oct 12, 2013Explorer II
For noon (1300 fast time) at 46N you know Dec is 23 on 21 June and Zero on 21 Sep.
21 June Noon Tilt is 46-23 = 23
21 Sep Noon Tilt is 46-0 = 46
change is about 8 degrees a month.
Roughly, Jun and July are the same, May and Aug the same, Apr and Sep the same
I get the right tilt for noon, getting panel Isc for amps then tip it up till I see amps drop so that tells me how much higher I can go and still get Isc at noon. After that, you have to pick something that you like.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
