high voltage i understand
he said 19 negative, reverse polarity charging
and battery at -9.5v
 The chassis battery voltage was reversed and read -9.5 volts, not a good thing, it was ruined! I was into finding out how this happened after disconnecting lots of stuff and finding a couple of blown fuses, I found that out of my solar panel controller it was putting out -19 volts,
he didn't mention controller mfg & model, or amount of solar
i don't know if an mppt controller could fail and produce reverse voltage, but i don't believe a PWM CC could do so
