CA_Traveler's avatar
CA_Traveler
Explorer III
Jan 04, 2016
Solar Panel Performance vs Panel Tilting
The following chart reflects solar panel performance for Denver, CO for the Summer Solstice on 6/20/16. The calculations are based on the USNO sun data which includes sun elevation and azimuth. The solar panel is also set to a given elevation (0 = vertical and 90 = flat) and azimuth. The RV Education website equations were used to calculate the suns angle on the solar panel and the power calculated based on 100W. The calculations do not reflect any parameters like air mass, atmosphere, temperature, shadows, etc. The calculations include the elevation and azimuth of both the sun and the panel.
The maximum sun elevation is 74 degrees and the sun azimuth is then 185 degrees. The solar panel orientation was set to the same values for the chart below. The chart shows the wattage for the day. Notice that for the early and late hours there is no panel output because the sun is behind the panel.
The total wattage for the day is 846Wh.
The following chart shows the Sun elevation and azimuth for the day. The right hand scale is for the azimuth.
The suns azimuth changes 243 degrees during the day.
  • I don't tilt my panels anymore because I don't want to risk damage to my roof, or breaking my leg either.
    It is now cheaper to get an additional panel than to tilt and worry about your time on the roof.
    I can recall my first 90 watt system with controller, mounts, wiring, ect. for $750. Then upgrading in 96 with a 75 watt panel for $375 - only $5 per watt! Later in 99, I installed some 120 watt for $429. Now you can get 140W for $229. Much less expensive than the original prices, and wages have gone way up, so what would have taken a couple weeks pay can now be paid off in one day's work.
    Good luck,
    Fred.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    CA Traveler wrote:
    Summer tilting makes little difference and leaving he panels flat is close to optimal. And panel azimuth makes virtually no difference.
    I'm working on the winter charts where tilting is very beneficial. Also advancing the panel azimuth can help compensate for those noon clouds. :)
    I chose Denver not for the weather but because it's about mid latitude for the lower 48.
    I disagree that tilting doesn't make a difference in the summer. Further south, likely, but up north, it does. Not near as much as fall/winter/spring but it does.
    I see about 20% increase in output in the summer between a flat panel and one tilted properly at 45 degrees north.
    Easy way to set panel optimally
    hold a empty TP or paper towel tube perpendicular on the panel
    Adjust for zero shadow.
    Done.
    If I'm not around for the day, I set it for ideal around mid day.
  • Summer tilting makes little difference and leaving he panels flat is close to optimal. And panel azimuth makes virtually no difference.
  • That can't be Denver, there are no clouds at noon. lol
    Tilting in the summer cost you early and late, plus doesn't benefit much at noon over flat. Tilting in the winter makes much better sense due to limited loss early and late and a large benefit over flat at noon.
    Now unless we are in a drought year, if you come here in the summer, tilt to the south east. Take advantage of the morning sun before the clouds roll in between 11 am and 1 pm and drop them flat after that.
  • Unless you are going to have a tracking system either automatic or manual, I suggest you set your tilt for the latitude in which you live. You won't get max current all the time, of course.
    The perfect system would automatically track the sun all day long, but that means a complex system with motors to drive the panels. In addition they would have to be de-deployed when the rig is not in motion.
    I like that you did the research and provided the charts.
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
