ktmrfs
Dec 27, 2015Explorer III
want to get your panel at optimum angles quickly???? Here is the solution.
Tools needed
1) Sun
2) tube from a use Toilet paper roll, paper towel roll
3) One hand.
Method.
1)place the tube perpendicular on the panel.
2)Orient the panel to the tube cast NO shadow on the panel.
3) prop the panel in this position.
Takes all of about 30 seconds.
Once you have done this a few times, you'll find that "eyeballing" the postion gets you darn close, probably close enough.
If you do this around mid day you will also be close to the optimum position for daily average collection as well.
That will place the panel perpendicular to the sun which is exactly the orientation for maximum solar collection.
Panel will be close to the latitude + sun asmiuth.
Tools needed
1) Sun
3) One hand.
Method.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 29, 2026
