justme
Dec 31, 2015Explorer
Salvo wrote:
Actually flexible panels have several drawbacks.
When using a mppt controller, panel performance degrades with increasing temperature. It's good to have a 2" gap between the roof and the bottom of the panel to allow bottom side cooling. Flexible panels don't have that back side cooling capability. Performance suffers.
Flexible panels are not as efficient. To get the same wattage, you need about 20% more surface area. RV roofs have a limited usable roof surface area.
An interesting point. How did you come up with the 20%? I did not experience this heat effect with my mppt controller and 200 watt panels on my boat that is made out of fiberglass which does not distribute heat.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
