pianotuna
Dec 31, 2015Nomad III
Did you test your system with an air gap of 4 inches under the panels? Did you measure the temperature of the panels? Did you check the makers specifications for voltage loss per degree C? If not, how do you know you did not experience the heat effect?
justme wrote:
An interesting point. How did you come up with the 20%? I did not experience this heat effect with my mppt controller and 200 watt panels on my boat that is made out of fiberglass which does not distribute heat.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
