justme
Dec 31, 2015Explorer
pianotuna wrote:
Did you test your system with an air gap of 4 inches under the panels? Did you measure the temperature of the panels? Did you check the makers specifications for voltage loss per degree C? If not, how do you know you did not experience the heat effect?justme wrote:
An interesting point. How did you come up with the 20%? I did not experience this heat effect with my mppt controller and 200 watt panels on my boat that is made out of fiberglass which does not distribute heat.
I simply glued the flex panels down and they work fine. Are they as efficient as my non-flex panels that are mounted on the surface with clamps(with no air space)-- I have no idea, but they both perform well for my application. Also, the flex and non-flex panels both absorb a lot of heat during the day. My IR gun measures the heat on both of them to be near the same.
Do you have some empirical data that you have actually measure that you can share. That is what I am looking for rather than some theory stuff. Like they say in Missouri-- show me :-)
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
