Almot
Dec 31, 2015Explorer III
red31 wrote:
one needs to compare specific panels and their specific specs vs generic. There's no need to compare a $500 100 watt flex to a $90 framed one.
Framing in itself is not relevant to nominal wattage.
Poly/mono are framed.
Amorphous panels can be framed or flexible, but as long as it's amorphous - and flexible panels always are - it will have less nominal wattage per sq.ft. than poly/mono.
You are right, this info is easily obtained from the manufacturer - by looking into specs.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
