EsoxLucius
Feb 22, 2014Explorer
Several observations:
1. You have a lot of room on the left side. I know you may be set on the panels you will use, but I would look at bigger panels to fit that space.
2. You can put panels over those circular vents on the right side.
3. I'd consider two larger 24 volt panels on the right side if they will fit, and two small 12 volt panels in series on the right over the vents and behind. That would make me consider an MPPT controller.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
