- Tom_M1ExplorerCostco is selling a Grape Solar 100 watt panel for $139.97 including shipping. It's not the same panel that AM Solar sells, but it's an attractive price.
Grape Solar 100 watt panel. - EsoxLuciusExplorer
pianotuna wrote:
Yes, AM Solar sources their solar panels from Grape Solar in Eugene, OR which is right next door to Springfield, OR. I wouldn't be surprised if Greg Holder has a stake in Grape Solar.
gs-100
Is that grape solar? or? - mena661Explorer
Salvo wrote:
I did say that N-S will be the orientation after the recommendations here. Yours is just one more reason to keep that layout (N-S that is). I do have to ask to make sure. :)
Some of your orientations are running parallel to the rafters. It's unlikely you'll be able to screw into them.BFL13 wrote:
This might be difficult for me.
Mena it will come out right as long as you remember--the square pegs go in the square holes; the round pegs go in the round holes. - SalvoExplorerSome of your orientations are running parallel to the rafters. It's unlikely you'll be able to screw into them.
mena661 wrote:
Salvo wrote:
This was more of an orientation and how much room do I really have exercise.
What happened to finding the rafters? Isn't that a priority? The panels need to run 90 degrees to the rafters. - BFL13Explorer IIMena it will come out right as long as you remember--the square pegs go in the square holes; the round pegs go in the round holes.
- mena661Explorer
Salvo wrote:
This was more of an orientation and how much room do I really have exercise. I don't think hitting the rafters will be a problem. I have been up there with my stud finder before but I don't trust it (its a cheapie). I'm not done just yet.
What happened to finding the rafters? Isn't that a priority? The panels need to run 90 degrees to the rafters. - SalvoExplorerWhat happened to finding the rafters? Isn't that a priority? The panels need to run 90 degrees to the rafters.
Sal - mena661Explorer
EsoxLucius wrote:
That's pretty impressive!
But before I left I checked the meter and they were still cranking 5 amps through that ice.pianotuna wrote:
AM Solar panels.
gs-100
http://www.amsolar.com/home/amr/page_13/gs100.html - pianotunaNomad IIIgs-100
Is that grape solar? or? - EsoxLuciusExplorer
mena661 wrote:
They are amazing panels though. This morning I took the snow off them but couldn't get about a 1/4" of crusty ice under the snow off them and I couldn't see much black under it. When it started snowing here Thursday afternoon it was about 36 degrees F and that's what caused the crusty ice under the seven inches that fell later. I planned to come back later in the day with a better ice scraper and get it off. But before I left I checked the meter and they were still cranking 5 amps through that ice. They might have done more but it was in float. When I came back there was only a little to do as the sun had melted most of it even though the high was only 15 degrees F today.
If those weren't so damn expensive they would be the hot ticket.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
