BFL13
May 03, 2018Explorer II
Yes it matters. They should be marked, but if not, put your multi-meter on voltage across the two wires with the panel facing the sun so there is some voltage.
If you have pos to pos, the meter display will say, eg 34.2, but if you have neg to pos, the meter display will say - (minus) 34.2. So now you know which wire is which, put some red sticky tape on the panel's pos wire.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
