Rbertalotto wrote:
I just checked amp using this video to teach me how to use the meter. As the clouds rolled in and out I was getting between 1.5 and 4.2 amps.
but it is not showing up on the little panel meter or on the Trimetric. The trimetric is showing a -.2 amp draw (CO2 and Gas Detector is the only thing hooked up at the moment)
If I have +/- 2 amps being delivered to the controller, wouldn't the TriMetric be showing a net gain?
Like Mr. Wizard said, it doesn't appear your meters are wired correctly hence not right readings. Your direct amps reading in this post seem reasonable for a 120w panel so it is working
