dpgllg's avatar
dpgllg
Solar panel questions
We just got our new 2017 Grand Design 27RL 5th wheel last month. It has a Furrion solar panel port on the front basement wall. The dealer briefly explained that I could connect a solar panel to this port to charge my battery.
I have looked into the panels that Furrion provide and they are 95watt folding suitcase type and cost around $500.At that amount it is currently beyond my finances so I am looking for a more cost effective solution.
Furrion Solar Pane
My purpose for adding a solar panel is to maintain the battery while in storage. We do not dry camp or boondock at this time. To access all areas of my 5th wheel I have to put out at least the passenger side slide out. I have no idea what power is consumed by this but do not want to get stuck sometime and not be able to get slide in our out. Or worse only partially in or out.
I have located a connector that will work with the Furrion port for $10 so I can wire any solar panel to work with it. The Furrion port DOES NOT PROVIDE ANY TYPE OF VOLTAGE CONTOLLER. This means that any panel I purchase has to have this capability.
I am not sure how many watts I would need but the trickle charger panels I saw were from 6 to 10 watts.
This is one at Tractor Supply that is 6 watt with overcharge protection. It only costs $60.
Tractor Supply Coleman Solar Panel
Will this adequately maintain a 12v battery? Do I need a larger more watt panel? Is the overcharge protection that is built in sufficient?
It is a Amorphous solar panel while the 95 watt Furrion is a Poly Crystalline. Is one better than other for my needs and why?
Thank you in advance for your assistance
Dave
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
