Itinerant1 wrote:
... battery bank normally gets back to 95-100% even after a couple/ few days of playing catch up but in this location it's been getting to 70% (350ah) by sundown ...
That's what seemed odd to me that I wasn't gaining back the lost power after a couple days of heavy overcast and snow. The way I'm parked and the path of the sun is enough for the antenna shadow to stay on the panels a fair amount of the day.
Hard to tell why it couldn't catch up to 95% when changing the location. Antenna shade could've contributed, or this location had some trees/mountains blocking the early sun when you needed it the most, or there is less sun in late October than it was in August :). Or you changed the time pattern of loads. Increased current is needed only until you get to Absorb, then you can get by with very little charging current - until you turn some heavy loads on. If battery can't catch up past 70% - change the way you run loads, avoid running heavy loads after sunset.
Most solar systems require a fair amount of self-discipline, charging all the tools and running other loads is better in daytime - especially after the battery went to Float. Then you could use the energy from the sun directly, rather then discharging the battery. Battery stays in Float, sun runs your devices.
