BFL13
May 23, 2015Explorer II
CT_WANDERER wrote:
When you pro's talk, having solar panels sized to battery amp size, are you referring to total battery capacity or the 50% useable battery capacity? I am working on my Solar system, I have a total house bank of switch-able 410AH on Bank#1(GC2) and 170AH Bank#2 (Group24). I plan on installing 5 X 120watt panels. I figure this should work good. Is my plan good? Thanks Gary
(I understand the question even though I do not agree with those who do relate their solar wattage to battery bank size as the way to do it.)
The answer is they use the full rated AH capacity of the bank, not just half of it.
Second question is whether 600w is enough for 580AH of bank. Answer is "It depends" on:
-how many AH you need to replace daily with the solar (as a side note, if you do some of that with the generator/charger, that would be less solar needed)
- how the panels are mounted flat or tilted
-your latitude, and time of year for how much sun you can expect. "Just enough" solar for summer is "not enough" for winter.
That AH replacement amount is the same no matter how many batteries you have. How many batteries you need is also related to your AH usage of course.
If the solar is doing some of the AH usage as "extra" as well as recharging the batts, then you won't need as many batts to stay above 50% .
But if some of that AH is high draw like microwave inverter then you might want more batteries to stay above the inverter's 11v shut off during the high draw times, even though for straight AH count, you don't need that many batteries to stay above 50% resting.
Solar amount and battery amount requirements are two separate calculations, but each is based on your daily AH usage.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
