reed_cundiff
May 23, 2015Explorer
RoyB - great going on planning for that much solar on a popup. Ground mount solar panel means you can adjust angle to get maximum insolation. Ours are all roof mounted on 34' 5th wheel, but we have sufficient panels to mount flat.
Reed and Elaine
34' Open Range 337RLS 5th wheel (cheap but quite nice)
2006 Chevie 4x4 diesel (dualie) w/50 gallon Transferflo auxilliary tank
1.4 kW of panels (6 x 235 W): 2 sets of 3 x 235 W in series then parallel to
controller at 90 V
8.7 kW-hr (at 48 V nominal) LFP battery suite (7 kW-hr usable)
4.0 kW Magnum PSWI
1 kW Honda (only turn on every month or so to make sure it still works)
Reed and Elaine
controller at 90 V
4.0 kW Magnum PSWI
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
