full_mosey
May 23, 2015Explorer
Hi Roy;
What do you mean by " When it tapers back after about an hour of charge running then generator then I will be able switch to the solar panels."?
I have two solar systems(TT and TV) and the solar is never disconnected. Genny charging is done in parallel. The genny is shut down when it drops to idle.
HTH;
John
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
