pianotuna
May 23, 2015Nomad III
Hi CT,
Total capacity.
You could go as high as 870 but 600 will work well unless there is lots of inverter usage. If there is, then max out the entire unshaded roof space. For a full time situation I now lean towards maxing out the solar install.
Total capacity.
CT_WANDERER wrote:
When you pro's talk, having solar panels sized to battery amp size, are you referring to total battery capacity or the 50% useable battery capacity? I am working on my Solar system, I have a total house bank of switch-able 410AH on Bank#1(GC2) and 170AH Bank#2 (Group24). I plan on installing 5 X 120watt panels. I figure this should work good. Is my plan good? Thanks Gary
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
