robatthelake wrote:
What You have is a fine way to introduce yourself to Solar ,many of Us began with less.
If You have 2 x 12 Volt Batteries they are connected to each other in Parralell ...Positive to Positive and Negative to Negative. The Lead Battery is the one that has the Positive feed attached to the Fuse Panel!
If You have 2 x 6 Volt Batteries they are connected to each other in Series! Positive on One to the Negative on the Other. This results in One Large 12 Volt Battery. In this case the Lead Battery would be the One whose Positive Terminal is connected to the Fuse Panel.
In either case be sure that The Wire from the Solar array is connected + Positive to +. And the Legative is connected to the - Negative or Ground to the Frame!
May I suggest that You Google Search " The 12 Volt Side of Life"
Thanks for the feedback... I do have + to + and - to - between the batteries (I did get that much from the 12v side of life when I got my second battery), but to hook up the portable solar panels to the battery is where I'm in the dark at.
For all I know it doesn't matter and I'm making a bigger issue of it than it is. :)
