bcarroll's avatar
bcarroll
Solar panel to 2 batteries...
This is a total newb question but...
I just purchased a 100W solar suitcase to use on my 2 12V batteries.
I know enough about electricity to know I don't know what I'm doing and don't want to do anything wrong.
I have looked on line and it says I can hook it up but it says to do so on the "lead" battery....which one is the lead batter?
Do I just pick one and that's the lead battery?
Do I hook up the negative to one battery and the positive on the other?
Please help my ignorance...
  • Dakota98 wrote:
    Connect in parallel as show.
    Top battery is "lead"
    Maybe I don't have my batteries hooked up correctly... I have the negative from the trailer going to one battery, and the positive from the trailer going to the second battery... of course neg to neg and pos to pos from one battery to the other.
  • What You have is a fine way to introduce yourself to Solar ,many of Us began with less.
    If You have 2 x 12 Volt Batteries they are connected to each other in Parralell ...Positive to Positive and Negative to Negative. The Lead Battery is the one that has the Positive feed attached to the Fuse Panel!
    If You have 2 x 6 Volt Batteries they are connected to each other in Series! Positive on One to the Negative on the Other. This results in One Large 12 Volt Battery. In this case the Lead Battery would be the One whose Positive Terminal is connected to the Fuse Panel.
    In either case be sure that The Wire from the Solar array is connected + Positive to +. And the Legative is connected to the - Negative or Ground to the Frame!
    May I suggest that You Google Search " The 12 Volt Side of Life"
  • Connect in parallel as show.
    For reference only, ignore the A/H, as shown. Yours will be different
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
