The 60-cell panel Vmp = 31.26V. The question is: at what temperature does Vmp drop to 29.6V. I'm saying Vmp is at the edge of the IV curve cliff and therefore a valid interpretation where the controller can't output 29.6V.
Did you say you had 1.7% line loss between panel and controller?
Controller input voltage after line loss is:
Vin = Vmp * (1-1.7%) = 30.73V
Now we calculate the temperature rise that causes the voltage to drop from 30.73V to 29.6V. Vmp temp coefficient = 0.4%/C
Delta T = (1- (29.6V / 30.73V)) / 0.005V/C = 9.2C
At 34.2C (25C + 9.2C) the controller will have difficulty supplying 29.6V to the battery.
BFL13 wrote:
The question is how high must panel temperature be so you can no longer get the 24v battery to say 29.6v ( twice 14.8)?
