Do your in line current monitoring on the array side for the 24 Voc panel
The controller gets its operating power from the battery connection - interrupting this connection will confuse the poor little thing maybe even worse could kill it
I assume Vmp for your 24Vdc panel should be about 20Volts thus the current should be just about 10amps might save a few fuses
A few benefits of a clamp on meter, NEVER any fuse issues, no need to interrupt the circuit and far faster connections, might not be as accurate but not an issue when looking for a max number
